It is currently Sat Jun 21, 2025 5:15 pm
PostPosted: Wed Feb 08, 2006 2:26 pm
Where is the best place to get Large buffing wheels? (12",14", or 16") I'm going to rig up my own buffer with an industrial baldor motor and a 10:1 high torque gear reducer and I would like to use a large buffing wheel. The output on the reducer is a 3/4" output so if there is someplace that has a solid 3/4" arbor, then I wouldn't have to modify anything. Has anybody tried this yet?? Thanks for your help.Iplaytheoldies38756.9516550926
PostPosted: Wed Feb 08, 2006 3:54 pm
http://www.caswellplating.com/buffs/index.html
   try this place.
john hall
PostPosted: Thu Feb 09, 2006 1:14 am
i second john's suggestion of caswell.
however i doubt the wisdom of using a high torque motor drive on your buffer.
low torque/power will help prevent burning your finish; if you apply too much pressure the buff stalls. with a high torque drive the wheel will continue to spin and you can very easily burn your finish.
i only use a 1/3 hp, 1750 rpm motor reduced 2:1 yielding 875 shaft rpm with 12" buffs. works fine.
PostPosted: Thu Feb 09, 2006 11:57 am
thanks for the suggestion
